Rear hub freewheeling
Shifty
249
444
Wiltshire
Bike Trance E+3. Just oiled the chain on the stand turning pedals turning rear wheel. Walked bike out of garage and hey presto hub freewheeling and not moving the bike forward?
Bloody bike!!
net wurker
185
237
Huntsville, AL USA
So for clarity, your bike was fine. You put it in the stand to oil the chain, and it was still fine. Then on the roll out of the garage, the rear hub stripped or otherwise broke somehow?
Have you tried to diagnose it any?
iXi
424
321
Brisbane
Welcome to giants dodgy hub. Lots of write ups on here how they just fail. Should be covered under warranty
Shifty
249
444
Wiltshire
I see the write up. I have sent a short vid to the bike supplier JEJ and will see what they say. Bikes only a few months old
Mickmick
Kent
My hub broke on a ride. Took it to lbs. they changed the hub under warranty. Did 12 miles on new hub when it broke too. I’m talking to giant tomorrow. Apparently hope or dt Swiss do better hubs
The Flying Dutchman
340
556
Wellington NZ
Gutted! Giant is pretty good when it comes to after-sales care. Push for an upgraded hub. I've been on a Hope Pro4 for 10 months without issue.
How old was your bike when the first hub failed?
Evolution Stu
457
448
Blackpool. U.K.
having seen mine repaired in front of me, I’d just while the freehub out and check it’s not the greas viscosity problem a large batch left Giant with. The pawls stick down and allow a freewheel situation. Literally 20 mins to remove, clean, re-grease and re-assemble
Yetibos
62
40
Taiwan
yeah, the problem is just that stupid grease in the pawl system ... also some hub cups are not very tight so the freehub get loose which means problems with the axle.
I checked it myself, just clean it properly, and put fine oil, not grease .... it works very good now.
552K
