Hi!
I know this is not directly Giant related but because my bike is a Giant Fathom E+2 Pro I will try to ask for help here
Recently I replaced the rear break with a mt520 double piston caliper. I replaced the Hose and the lever as well (deore xt m8000). I did the same with the front brake. The front brake is working perfectly.
The problem with the rear brake is that it is softer or harder depending on the moment. Sometimes it is pretty hard (almost no travel) and sometimes it works as it should (similar to front lever).
Do you know what could be the cause? I have tried 2 different levers and some bleedings with no improvement.
thanks!
thanks!
