Rail rear rotor replacement
ronianash
33
30
Squamish, BC
I smashed my rear rotor and need a replacement. Is there any trick to taking off/putting on the magnet and do I need to reset anything in the computer once I replace the rotor?
BrentD
168
134
New Zealand
The magnet seems to be simply held on with the rotor bolts on my Rail. I'd imagine it should be a simple matter of swapping rotors and not forgetting to reattach the spoke magnet when installing the new disc.
Doomanic
🛠️Wrecker🛠️
8,715
10,378
No special trick, just add a drop of thread lock to each bolt, you don’t want them coming loose and sawing through the chainstay!
554K
