Hello evening everyone
Apart from the Obvious that you don’t need tools for a quick release axle
Which is best to use ??
When you say QR, do you mean the older style axles that fit into an open slot on a fork or the frame, or the type of axle that screws in but has an adjustable locking tab that you use to loosen/tighten the axle as apposed to those that need an Allen key to remove?Sorry I guess from a safety / reliability point
They're both thru axlesbasically I am changing my fork to a lyrik and the lyrik came with a quick release axle
the rockshox 35 that came as stock had a solid axle which uses a hex key
Safety in what way?I wondered from a safely point of view which would be better to keep and use on the bike
