Other Pump it up
Squatch
26
28
Washington State
This one will.... Air Tool MTB Mini V2 with Bracket | Specialized.com
I used it with the included pump bracket while using the water bottle cage bolts. It is short so it fits with the stock cage/tool. I ultimately went to this set up (pictured) because I'm now using the Fidlock water bottle and the pump would not allow me to twist the bottle off. So now I use these.
Dirk74
99
55
@Squatch , good idea :)
Have you checked clearance for the rear tyre (release all air from the rear shock)?
I own a Topeak Racerocket MT pump, which is a bit thicker and had to move it to the side of the seat tube.
Konanige
422
336
Mendips
Update, One up components 70cc EDC pump fits perfectly, nice wide bracket pushes pump out past frame so no rubbing or rattling. Its not cheap but its a lovely quality piece of kit and unfortunately has been tested on two rides now and proven its value.
backstep
18
8
Valencia, Spain
I've got the same pump but its not clear where best to mount, would you mind posting a photo?
552K
