E-volution
So this is my question. The Boxxer is a dual crown fork, the upper crown moves up and down depending on where you run your handlebar and how many spacers you have under the clamp to raise or lower the handlebar height. Seems that despite this people always adjust the fork so the top of the stanchion is level with the top of the top clamp, this can't be right. Rockshox says you always measure from the bottom clamp 163 +/- 2 mm to the top of the stanchion the position of the top clamp is irrelevant. Obviously the position affects the geometry and weight distribution on the bike. Does anybody have an idea what the default setup is on the Kenevo is ?. Thanks in advance
