Evening all,
I was wondering if someone could help me with a question about my Fox DHX2 coil shock on my 2020 Norco Range VLT C2 (second hand).
I was trying to make some adjustments to the shock and can make the low speed adjustments that use the 3mm hex OK but when it comes to the high speed 6mm there is what looks like a black plug/collar in the way. When I look at images of the same type of shock as mind from the web (attached) the black plug/collar isn't there - should I remove them?
This is driving me crazy as I really need to make the adjustments.
Cheers,
Scott
Cheers,
Scott
