problem with Bosh Ebike-Connect Nyon and Strava POWER
yagg
france
Hello, I have a power synchronization problem between Bosch Ebike Connect and Strava which has lasted for 1 year. The data is correct on Bosch but when I export it to Strava it is not good
example:
On Strava
r/Strava - problem with Bosh Ebike connect and Strava POWER
On Bosch Ebike-connect:
I asked Strava and they tell me it's from Bosch. So I asked Bosch and they tell me it's from Strava :)
I use a Bosch Nyon on my VTTAE I reset it, I also tested with a new brand new Strava account but the result is the same
I transfer my data from Ebike-Connect (Bosch) to Strava. This is a TCX file
I noticed that between TPX tags the power data only appears every 5 seconds But I noticed that between the TPX tags the power data only appears every 5 seconds
Example:
<Extensions> <TPX xmlns = "http://www.garmin.com/xmlschemas/ActivityExtension/v2"> <Speed> 5.297222 </Speed> <Watts> 377 </Watts> </TPX> </Extensions>
<Extensions> <TPX xmlns = "http://www.garmin.com/xmlschemas/ActivityExtension/v2"> <Speed> 6.3555555 </Speed> </TPX> </Extensions>
in the last part the power data is missing
I would like to know if anyone knows how to solve this problem which falsifies my data
552K
