Levo Gen 3 Praxis 36T on Comp Carbon
mvdh
10
Belgium
Hi all,
I have order a praxis 36T chainring (https://praxiscycles.com/product/ering-steel-mtn-1x-104bcd/#COMPAT) like several others are using for Gen2 that comes with threaded holes (M8).
Now am i removing the stock 34 sram chainring from my Gen3 and its not threaded anymore and they are using also M8,5 bolts.
Did someone already mount a 36 on a gen3 en which chainring did you used?
Or can i just mount it with new m8 bolts?
Or should i drill the threaded holes from the praxis to match the bolts and nuts from the chainring?
Pictures :
salko
1,274
865
SLO
Find new M8 chainring bolts and screw it right into the new chainring. Many Levos come stock with chainrings with threaded holes, I guess due to low parts availability they also mix some stock parts within the same models ...
SD_Levo
8
San Diego, CA
Hi all,
Pictures : View attachment 81488
How did you get that chainring off your 2022 gen3?
552K
