Powering a 48V cyclone motor rated at 36v-72v @ 80 amp on a 40amp controller
fabieville
Jamaica
had a 36v-72v 3000watt geared cyclone motor rated at 40amps in the past and i was operating it on a 48v 30amp battery pack with a 45A built in BMS and on a average it use to pull around 15-20amps on a flat terrain on full throttle and with the 40amp controller it never past 40amp the most i see it went to was around 35-37amps when climbing very steep hills.
So if i decide to buy the 36-72v 6000watt 80amp rated one and operate it using my 48v 30amp battery with built in 40amp max BMS would my 40amp controller that i have limit the max draw to around 35-40amp and also would i be drawing roughly the same 15-20 amp on a flat terrain at full throttle?
Also would i expect to get the same performance or better than when i was using the smaller 48v 3000watt motor?
Here are the links for both motor:
Top 10 best and Fastest electric dirt bikes Motocross Big Boy ebike DIY Motorized kit Fastest electric dirt bikes Motocross Big Boy ebike DIY Motorized kit Fastest electric dirt bikes Motocross Big Boy ebike DIY Motorized kit world's Fastest electric dir (3K model)
Top 10 best and Fastest electric dirt bikes Motocross Big Boy ebike DIY Motorized kit Fastest electric dirt bikes Motocross Big Boy ebike DIY Motorized kit Fastest electric dirt bikes Motocross Big Boy ebike DIY Motorized kit world's Fastest electric dir (6K model)
554K
