Pivot Shuttle has landed.
Pybo
67
71
Middlesbrough
Just picked up my Pivot Shuttle. Set suspension/tyre pressure and connected E Tube.
Fitted guards...hoping the rear will be ok ?.
First ride at Hamsterly Forest tomorrow...taking the GoPro as the weather is gonna be sweet.
I’ve got F16psi R20psi in the 2.8 minions as a starting point.
I’ll post up some feedback very soon.
Pybo
67
71
Middlesbrough
First ride on the Pivot Shuttle.... WOW
Hamsterly Forest..loads of off piste and lots of the legit stuff too.
We did 24 miles and 3500ft of climbing..still had 2 bars left and range said 15 miles let..very happy ?
The Shuttle was flawless, smooth and very quiet...and also very fast rolling. The suspension wasn’t quite as plush as my outgoing Patrol but was a very very good. Actually it felt nicer and more controllable. Still tweaking the settings but it’s not far away at all.
Couple of times I thought “could do with my 170’s here”, but then the 150 Fit4 just ate it up,..woohoo?? Very happy indeed!
Fork and shock performed brilliantly!
The bike (small) felt more nimble than the Transition and a few times in the off piste it was railing across ruts n roots faster than I would normally go. Half a pedal stroke and it was away!
We climbed some really steep techy stuff..amazed!
The rear brake is still not 100%...think it needs another ride in the pads. Although with the heavier bike it could be me grabbing a mit full a bit later than I should.
Controls: I’m waiting on the E6000 mode selector but the E8000 that’s on worked really well. It still lets me use the under bar dropper lever (wolftooth long).
The gear shifter needs the switches swapping in the app (Di2) as I constantly got the shifter mixed up.
Tyres:
the DHR2 2.8 max terra on the rear wa excellent at 20psi. Although I was a bit worried after reading about punctures n stuff.
Front is a DHF 2.8 twin compound (not the 3c) and was ‘ok’, but it will struggle when it gets wet I fear. This was running at 16psi. Still some scope for lowering pressure. A nice maxxi grip shorty in a 2.6DD would be wonderful (please Maxxix).
I’ve got some footage I’ll put up soon.
This is my first Ebike and I’m so so glad I took the plunge. Massive grin all day long!
Pybo
67
71
Middlesbrough
Tyres:
Couple off pics
553K
