Pinion MGU E1.12
21,315
We've arrived ..
10,000km oil change (10 minutes to do)
Smart shifting and also Pre-Select and Start-Select.
Batteries by FIT - 48v. Removable 480/720/960wh options or a 700wh integrated unit. There's also a 468wh range extender.
There's an app which lets you configure most things and decent looking controllers :
Basic Specs :
The Standard version has 600w peaks and the Speed Pedalec version has 800w peaks. If you're buying them, they are sold as different units (501070 from FIT for normal and 501109 for the Speed Pedalec version) though presumably they're the same hardware for ease of manufacturing and it's a firmware setting.
Launch Video :
There were initial prices shown via FIT but these have been removed :
21,315
S-pedelec is confirmed as same hardware.
Housing is Magnesium.
9 Speed version is envisioned for some Speed Pedelec usages where a larger jump between gears would be beneficial.
The screens on the bikes with the larger separate screens are removable and you can ride with an app instead if you prefer.
Sprocket installation :
Make sure you install the stainless washed over the sprocket :
Before you put on the lockring :
Pinion MGU Lockring is LEFT ! handed thread. So clockwise to REMOVE. Tighten to 40NM.
jgf
31
16
Canada
Would have thought we'd be seeing more mtbs using this system by now, but it looks liked there are still limited offerings from vendors I am not familiar with (and dont seem to have much of a north american presence at all)
Onetime
481
501
Cali
There is no North American presence because their batteries have not yet been certified. They cannot be shipped here until they are certified.
575K
