Pedals wrong way round.
billwarwick
682
1,557
warwick
I just put some new pedals on Bosch gen 4 and the pedals are the wrong way round . That is L pedal only fits on the right side and vice versa. The crank arms have never been taken off so does that mean that the bike was built like this? I never noticed this before. I tightened them up well but one still came loose. Never had a problem with the old pedals.Can the cranks just be swapped round and do I need a special puller? I’m a bit confused 🤔. Can I tighten the pedals up enough to keep them on even if they are on the wrong side ?
billwarwick
682
1,557
warwick
Just looked at cranks and the one that is chain side is marked 170L and the other one is marked 170R ?
Weeksy
611
670
Reading
The simple answer is... you can clearly fit the wrong side cranks on the wrong side... at the factory. Someone fucked up.
Obviously with a MTB crank you've got a spindle on one side and a chain ring on the other. With an eeb you've got 2 spindles... if they're exactly the same, then they can be fitted incorrectly. Someone did that, then fitted the pedals... which almost defies belief as that must be what they do 100 times a day in the factory lol.
billwarwick
682
1,557
warwick
I assume an LBS would be able to rectify as they would have the correct tools? I can’t believe that the pedals didn’t come loose until I put new ones on.
Weeksy
611
670
Reading
Yeah assuming you bought from them i'd be taking it in with a puzzled look of "wtf fellas" and seeing what they say. It's a 5 min job.
billwarwick
682
1,557
warwick
I bought it 100 miles away during Covid so won’t be going back there. I can get someone local to do it . Thanks for your helpful comments, 👍🏻
569K
