Save your cash and reconfigure the motor to USA which increases the restriction from 15mph to 20mph. You can go as far as 50mph if you program the wheel diameter to the smallest circumference. Obviously do this at your own risk as certain laws may be broken in used on a public road etc.. 20mph is more than enough for most.Anyone using this for their Bullit or Heckler? If yes what's your review.
And how do you that? How do you reconfigure to USA?Save your cash and reconfigure the motor to USA which increases the restriction from 15mph to 20mph. You can go as far as 50mph if you program the wheel diameter to the smallest circumference. Obviously do this at your own risk as certain laws may be broken in used on a public road etc.. 20mph is more than enough for most.
A quick Google search will tell you everything. Ultimately you need to roll back the software version to make these changes then once you've done that just update to latest software.And how do you that? How do you reconfigure to USA?
Hi @CRBB,
Did you find a solution for your Bullit ?Im thinking buying the peartune as when remove nothing can be found.If you rollback firmware they can see it and void warranty.
Lots of people say that if you do this and that, the manufacturer can’t tell what’s been happening to the motor — they’re utterly convinced of this. They’re wrong and my evidence follows.Where can I find the info on them detecting firmware downgrades ?
Hi @CRBB,
I use STUnlocker on my PC. You connect it via the Shimano SM-PCE02.
You don't have to downgrade your firmware when you connect to the PC and once you have made the change you can administer it via the STUnlock iPhone or Android app.
Really works a treat.
is stunlocker working for EP8 now ? , Has for me that vladl wrote in the stunlocker thread that it was a bit of a hassle with stunlocker for ep8.
I have an E8000 and EP8, both with the most up to date firware and I can alter settings on both when connected to my PC or Mac.
The hassle is that you need the SM-PCE02 and you need a Windows PC or Windows on Parallels on a Mac.
Honestly works a treat on both mine.
If you are UK/South East based I'd be happy to connect it up for you.
thanks for the offer but I have already changed my e8000 to US settings and it was very easy.. I have a friend who has bought a bike with ep8 and he was unsure if stunlocker worked
i would also be interested in this.I have EP8 Bullit & E8000 E160. what did you do/use to change to US settings???
STUnlocker can do it. Depending on firmware you will either be ok or have to downgrade it.
Or you can use STUNlocker on your PC and connect via the SM-PCE02. Then it doesn't matter what firmware you are on, you can change to US settings with all current firmwares.
STUnlocker - you need the premium licence
SM-PCE02- you need to connect this to your bike and PC
If you are in the UK/South East I'd be happy to help out.
See my comment a few months ago. These changes can be detected by Shimano for themselves and by Shimano for others, for example if the police take an interest in something on private land or the road. Changing the password doesn’t help as the info is preserved after a reset of that.Anyone with experience of Peartune 3.0 or Speedbox physical de restictor devices for Bullit / EP8?
Ive been told that Shimano are getting difficult (refusing) warranty claims as they seem to be able to detect that a UK bike has been re set to USA region and/or derestricted via software. Im trying to maintain my warranty at the moment so would prefer an alternative to ST unclocker.
