Pauliemon
C U LATER!
I've built close to 800 wheels. I used to own a mail order that specialized in custom wheels. Equal tension is the trick. But you need a tension meter.It fascinates me when someone tackles an install like this as a garage/patio mechanic. Are you trueing them yourself?
Throw out some details of your build. I’ve watched a number of videos on different types of techniques and models but I haven’t taken the plunge yet, but I can true a wheel …kinda.
I suppose I could justify a smancy-fancy tension meter (like that, nice)if I was truing more than 10 bikes (friends & family) but I’ve got the cheap one. I occasionally get the LBS to calibrate it but it’s still only “semi-accurate”. I think 20% tension range is acceptable for mtb’s but I try for 5% variance with a true wheel. I find the Park Tool tension app helps me visualize any problem spokes but I’m sometimes chasing my tail between tension and truing.Equal tension is the trick. But you need a tension meter.
This one is expensive and well used. Go to Sheldon Brown's site.
Probably a good cleaning fluid too .jamo BB is my go to .
You've got it dialed. You don't need a high end tension meter if you're not building a lot. The Park meter works great. The Park will last far beyond 10 bikes.I suppose I could justify a smancy-fancy tension meter (like that, nice)if I was truing more than 10 bikes (friends & family) but I’ve got the cheap one. I occasionally get the LBS to calibrate it but it’s still only “semi-accurate”. I think 20% tension range is acceptable for mtb’s but I try for 5% variance with a true wheel. I find the Park Tool tension app helps me visualize any problem spokes but I’m sometimes chasing my tail between tension and truing.
I’m looking at the i9 hydra 32 spoke. I’ve broken a few spokes (neighbour also) on our 28 spoke Bontrager stuff. I hope the hubs fail sooner than later so I can upgrade
I'm just impressed you downed a whole bottle of Jamesons ..and still had the clarity to do a wheel build ..
I thought same thing .I need glasses...that bag in the third picture looked like the contends were herbal rather than brass.
I was looking at the Nextie site and wondering which rim you chose. Why 28 spokes instead of 32?BAMBAMODA Yeah 28° x2, DT Champion 2.0 spokes, brass nipples.
The Hodge Many years experience.
With carbon rims and stiffer spokes it's as strong as a 32. Plus I only weigh around 170lbs/77kgs. Then the fact that I got a smokin' deal on some 28° Industry Nine hubs. I think when your building your own go with what makes you comfortable. The weight difference between 28° and 32° is almost nil.I was looking at the Nextie site and wondering which rim you chose. Why 28 spokes instead of 32?
Thanks! I have made a number of aluminum 26" DH wheels but never any carbon wheels. When you say Carbon is a stubborn bitch, does that mean when you are trueing or tensioning them? My wife recently bought me a set of WeAreOne carbon wheels with I9 hubs so my experience with carbon is very limited. For the type of riding I do, I have honestly yet to notice a difference between the WeAreOne wheels and the DT Swiss 511/Hope Pro 4 wheels we usually use (we also use Cushcore front and back and low tire pressure). My wife does say that I am incensitive but as a wheel builder, do you see THAT much of a difference to go carbon? I would be building a set for a winter project so I am thinking ahead. Where did you find the cheap I9 hubs? Thanks again!Just realized I didn't answer all your questions. I got the Premium Edition 36mm.
The majority of my builds were with alloy rims. I've only built around 10 with carbon rims. The difference is huge. Alloy can be manipulated and coaxed. Carbon is a stubborn bitch.
Whoa!, I had to read that twice.… My wife does say that I am incensitive but as a wheel builder…
Aluminum is softer than carbon. Alloy can get out of shape but you can coax it back. Carbon is flexible but it does not bend. Carbon will flex to a point and then break. Not that Carbon rims break all the time, they don't.Thanks! I have made a number of aluminum 26" DH wheels but never any carbon wheels. When you say Carbon is a stubborn bitch, does that mean when you are trueing or tensioning them? My wife recently bought me a set of WeAreOne carbon wheels with I9 hubs so my experience with carbon is very limited. For the type of riding I do, I have honestly yet to notice a difference between the WeAreOne wheels and the DT Swiss 511/Hope Pro 4 wheels we usually use (we also use Cushcore front and back and low tire pressure). My wife does say that I am incensitive but as a wheel builder, do you see THAT much of a difference to go carbon? I would be building a set for a winter project so I am thinking ahead. Where did you find the cheap I9 hubs? Thanks again!
Yeah Stihdog alloy rims are just as good. I mean none of us need carbon we just desire it. There are plenty of reasonably priced hubs out there also. If you think I9s are expensive check out Chris King, YOW! I scored the I9s for $400US with 6 hole adapters. That's me, always looking for good deals. I just got a Specialized Slaughter tire for $14US.I’m not snapping spokes like my neighbour who has the same bike (rail 9.7) . 28 spoke alloy Bontrager wheels and hubs. He’s 25-30lbs heavier than I and more aggressive (yet less incensitive ).
I just got a quote for the i9 hydra hub (I was shocked) but I’m considering keeping my alloy wheels (28 spoke). This would also be a winter project and my first try at lacing. I’m also considering the Tairin silent hub (based out of Surrey BC.)
I don’t think I need the carbon wheels and my existing alloy 28 spoke could keep the price down. I’ll probably go to the LBS (trek) with him and see what happens.
I am guessing your wives don't read this forum as that one line just blew up my months worth of prepping "Oh yes honey, carbon is WAY better for us than aluminum which is soooo pedestrian. It will make us ride faster and longer, jump higher and farther and basically live much longer. Carbon parts are basically functional diamonds!"Yeah Stihdog alloy rims are just as good. I mean none of us need carbon we just desire it. There are plenty of reasonably priced hubs out there also. If you think I9s are expensive check out Chris King, YOW! I scored the I9s for $400US with 6 hole adapters. That's me, always looking for good deals. I just got a Specialized Slaughter tire for $14US.
