Park Tool PRS 22.2 mod for Ebikes
6,544
5,032
As standard the PRS22.2 platform bike stand has a fork/thru axle mount on the front end and a spiked fitment at the back end that fits either side of an anlague bike bottom bracket. The latter is obviously no good for an EMTB so I replaced with a homemade "cradle" that the motor sits on.
I made this one from 2 heavy duty L brackets ( from B and Q). New holes were drilled to bolt the cradle to the 2 slider plates that enable the cradle position to be adjusted along the platform as required. Longer bolts that the originals were required. A piece of heavy duty rubber is fitted in the bottom of the cradle with holes drilled to retain access to the 4 bolts. The sides are covered in neoprene.
553K
