Overrun will make you a faster rider, but will it make you a better one?
Arcerhawk
Italy
Overrun seems to be key to win power stages and, ofcourse, every weekend warrior wants it. Bosch has it and Shimano's upcoming update will give you the chance to turn it up to a similar level to Bosch.
But, are we really sure that overrun is such a good thing? It might get you up the hill faster, but it might also mess up your technique, promoting brute force over finesse and control.
Personally, I ride a Shimano EP801. I'm waiting for the update to hit the eTube app and try the extended overrun.
However, I like to ride trial-like trails and I indulge in pedal kicks and the likes. I have a moto trial background.
What little overrun I get from the EP801 is still enough to throw me off balance. The only time it helps is when going full steam up a steep rocky section with little style and lots of hope.
So my question is: will this drive to ever more overrun kill a more technical riding? Should you avoid overrun at all when riding trials, expecially downhill?
glixerd
18
14
Athens
Had the overrun feature in my EP801 for about 3 weeks now.
It's helpful sometimes, not others
As it's helpful more times than it's not, i leave it enabled (Currently at Max)
If you don't like it, you just set it to minimum
Personally i cannot feel it at minimum, so it doesn't seem intrusive
Keep in mind it's also cancelled out if you backpedal
B1rdie
893
1,096
Brazil
^^ This!
Overrun only makes sense to me if it can be shut down by backpedaling, since this is the technique I use to shift without banging the drive train.
theremotejuggernaut
382
270
It feels like there's a small amount on my EP8 when it's in boost. I quite like it for clearing steep, steppy, rocky stuff that I wouldn't be able to pedal up. It does take away from the natural feel that the morltor gives though. I'd like the option to play with the settings and see what it was like with more but I think once the novelty had worn off, I probably wouldn't use it much.
There's too many situations where it's not helpful. I don't always want the bike to surge forward and keep going once I've stopped pedalling. If I've stopped pedalling, it's usually because I want to slow down!
Husky430
643
1,051
Glasshouse Mts - Australia
I can't speak for the Shimano over-run but on the Bosch I find that it helps me actually get up steep rocky sections that I would otherwise not even attempt. And I too love this more technical riding tho I will confess, I'm more of a "crash bandicoot" than a trials expert. :ROFLMAO: Still love to give it all a go and much prefer this type of riding than cruising down a fire road.
552K
