Orbea Wild - Range extender Q?
Sidepod
584
395
Oxford
It’s it possible to ride the bike using only the external mounted range extender battery and the in-tube unit removed?
Gyre
630
422
Pasadena, CA
For what it's worth, it looks like you can't charge the external battery through the frame port if the internal battery isn't mounted, so you'll need to disconnect the external battery and plug it straight into the charger every time you want to charge. Not a huge deal, but annoying all the same.
yolo_MTB
51
13
California/USA
This is awesome to hear, about to install my 400. Nice to be able to charge one while riding, or to have a lighter bike rocking the 400 on short days. As far as battery drain, guessing the system pulls from whatever battery has more juice left first, then will discharge evenly after?
yolo_MTB
51
13
California/USA
Nice! Also, I have not found any kind of install guides or instructions online. I would prefer to do it myself if possible. Do you have to drop the motor to access the wiring harness? Any tips would be great!
Thanks!
yolo_MTB
51
13
California/USA
So found it.. The PDF on Orbeas site has the following which might be useful to the next person...
I will still have to figure out exactly where the wires go but this is a good start...
552K
