Orbea Wild headset to replace SIC headset for normal stem
simple_ben
13
I am trying to find the Orbea part to put a normal stem on an Orbea Wild SIC headset. I need it so I can use a kids ride shotgun that requires a normal headset spacer.
I’ve heard it exist, but I can’t find it anywhere. Links or part numbers appreciated.
simple_ben
13
Good to know @Gw0175 I ordered a Large. Will take. Look right away, Incase I need to return. I did mount a Kids ride shotgun to a ‘21 wild with no issue. But it had the normal headset cable routing.
Gw0175
150
232
I think large is fine from what I've heard so hopefully you're all good! May be a bit crammed fitting the shotgun once you've swapped the stem spacer for the shotgun spacer due to cables still effectively coming up from the headset but I'm sure you'll manage!! Good luck 🤟🏻
simple_ben
13
I haven’t ordered the adapter yet, €10 shipping on a €29 part. But I have taken apart the headset, oofff cable integration here is tight 😱. It should be possible though without real issue
simple_ben
13
I'm about to order this adapter, I also want to mount a Shotgun for my kiddos to ride with me.
It's totally worth it, I have it on my Levo and my son hates to go a day without riding. I've from AZ originally as well! Tucson though.
554K
