Sold Orbea Wild 2023 Custom M Team Medium - £5750
Coff-E
Munich
Selling my custom Wild as I've just had knee surgery, so not riding for 9 months. This has <500km and was built as an custom spec from an M-Team base with a few alterations to the standard spec as per below:
Spec:
  • Frame: Orbea Wild OMR 2023, 160mm travel, custom raw matt carbon finish
  • Shock: Fox Float X2 Factory Trunnion 2-Position Adjust Kashima custom tune 205x65mm
  • Fork: Fox 38 Float Factory 170 Grip2 QR15x110 Kashima
  • Chainring: e*thirteen e*spec Direct Mount 34T Boost
  • Crank: e*thirteen Plus Alu
  • Headset: Alloy 1-1/2" black oxidated bearing
  • Handlebar: RaceFace Next R carbon, Rise35, Width 780
  • Stem: OC Mountain Control MC10 Alu SL, 0º
  • Shifters: Shimano XTR I-Spec EV
  • Brakes: XTR Hydraulic Disc
  • Cassette: Shimano XT 10-51t 12-Speed
  • Rear Derailleur: Shimano XTR
  • Chain: Shimano M8100
  • Wheels: OQUO Mountain Control MC32Team eBIKE
  • Tires: Maxxis Assegai EXO+ Maxxgrip/ Maxxis DHR DD MaxxTerra
  • Seatpost: Fox Factory 175mm dropper
  • Seatpost Lever: Shimano SL-MT500 I-Spec EV
  • Saddle: Fizik Aidon 208 x 145mm manganese rail
  • Chainguide: e*thirteen Plus Bosch CX Gen4 32-38t
  • Motor: BOSCH Performance Line CX
  • Battery: BOSCH Powertube 750Wh
I also have options for different build spec SRAM XO T-Type drive train, SRAM AXS 170 dropper, Fox Factory DHX2 with mullet adjust eyelet (to run the Wild with 27.5 rear). Pleaes message to discuss or if you have any questions.
Sorry these are only pictures I have at the moment
Mob: 07429447241
554K
