Orbea Rise with EN100 Junction Box
Packagingpro
Boca Raton, FL
Has any Rise owners running the EN100 Display switched to a Sram AXS Seat Post? If so, what did you do with the wiring once the dropper cable was removed? Any Pics are appreciated!
faberle
88
78
France Haute Savoie
What I would try to do is move the EN100 and switch to the right and make the wire follow/attach to the rear break hose. Alternative if you don't want to do this (as the clean way implies moving the wire from right to left frame hole, which might be a little difficult) is to attach wire/EN100 to the front brake hose (the wire part from frame hole to front brake hose will be a little floating).
mark.ai
828
594
Windermere
I've just left mine going through the same hole as it was - the dropper cable was also on the same side (but now removed).
If I ever switch to AXS rear derailleur as well, then I'd try to move it over to the same side as the brake cable.
I also moved the EW-EN100 down by the headtube, and removed the rubber sleeve around it - using my own clips as I prefer it.
547K
