LA_Stu
Hi!
I just got a Rise M20, and I'm wondering if anyone can answer a question about the water bottle mount please. The mounting bracket is quite loose. I made sure the central bolt is tight, but it really doesn't make any difference. So the bottle cage has a small amount of free play/movement. I solved the problem by using a couple of plastic washers between the bottle cage and frame (so that there's tension between the cage and frame), but I'm wondering if they're all like this?
Stu
Stu
