By far the best manual I've ever seen for a bike - covers bolt and torque for nearly everything. Breakdowns of all the parts, part numbers for replacement. Truly excellent.
Just a shame nearly every bolt spec seems to be wrong! 3mm where it says 4mm. Cross head screw where it says hex (for the motor guard), Torx where it says hex. Threadlock used where it says grease (though it doesn't seem to say thread lock anywhere)
Also, anyone know if all thread lock brands are the same colours? Loctite is normally blue 'mid strentgh' used for nearly everything, red for high strength (usually needs heat to remove - dont' use on bike if you want to get it out). A number of bolts seem to have some red thread lock on (but I did manage to remove them.
