OneUp Carbon vs E Carbon
Ktmkirby
Niagara
Any reason to go with a OneUp E-Carbon bar over the Carbon Bar on a 45lb Rise M10? I already have a OneUpn carbon on my analog bike, and thinking of just swapping.
ipe
13
13
White Mountains
E-bar is pre-drilled for wired controller and has a different damping/flex character vs the standard bars to account for the greater weight of the emtb.
FWIW, I've used both and been happy with both.
Julie_X1
136
115
Canada
I have the e-carbon one. I bought it because it’s supposed to be slightly even more compliant than the regular OneUp carbon bar. Something like 5% if I remember correctly.
It dampens vibrations very well but I’ve never experienced the regular bar to compare.
Mudrider
33
19
oxford
the difference is that you can hide the remote wires, the wire goes in at the middle of the handle bar, runs internally and comes out under the grip then there is a channel for it to run in and come out from under the grip as far as i am aware, you may need to change the length of the cable from motor to remote.
550K
