ReadyShreddy
I'm looking at getting a new rear shock and someone I know is selling the ohlins. Could anyone tell me if this is a suitable shock for the levo? What spring you use I weigh 90-95kg
Awesome thanks for the infoYeah all good man I run a ttx coil on my 22 levo , I'm 90kg and run a 571lbs spring
Thanks, yes it is 210 x 55 and luckily has the 571 spring with it.Great shock.
Check the one you're buying is metric (210x55mm).
If not, TFT converted mine when it was serviced (it was on my Gen2 Levo).
You cannot mount a 230mm shock with the original linkage. The damper is definitely 210mm long. The spring can have more stroke than the damper.
