Sold Ohlins TTx22m Coil Shock 230x60 Trek Rail
Bomble
661
386
Yorkshire
Ohlins TTX 22M Coil shock. I bought this from TFtuned at the end of 2020 as they recommended it for my Trek Rail, it starts as a 230x57.5 but they modded it to a 230x60 as they said it would be better on the Rail.
Comes with an Ohlins lightweight spring 548lb with 67mm stroke.
They also supplied all the mounting hardware to fit my Rail.( works out quite expensive) It was fitted to a 2020 Trek Rail 9.8.
I had it serviced by TFtuned at the end of 2021 and it has done about 10 rides since as I bought a new bike.
It’s in good condition with a few marks from usage. The worst marks and that some of the paint is cracking off the spring at either end, I’ve had a couple of Ohlins before that did exactly the same thing, I have tried to picture it.
Also the plastic wear sleeve has marks on it, as it is intended to do. They swap this out when serviced.
I believe these can be adjusted from 57.5 to 65.
£500 posted
552K
