Andy.M
A question, why are my rims offset?
Steve’s explanation although not technically correct kind of makes sense in a ŵay , makes me think he understands it anyway ?'spose it depends on the layman.
All replys so far except Steve's are correct.
I think we’re actually trying to answer two different questions here , your literally answering the reason spoke holes in rim may be offset Which is what the question reallyinferredThere's no rear cassette hub and rim combination that would require the drive side spokes to be vertical enough to interfere with the rear mech,chain or largest cassette sprocket
you'd actually have to build the wheel with the rim way off centre (out of dish) towards the driveside stays. And by doing so it would also be loads weaker
The reason for manufacturers producing some rims with offset spoke eyelets is to achieve more even tensions between drive side and non driveside spokes. Not for gear clearance.
I'm not really sure how I could put it any easier understand without needlessly going into far too much detail.
I'm not sure you achieved less confusion, but maybe added to it?All very confusing answers
surely ,the answer a layman could understand is its because the gear cassette , or freehub requires more space than the brake disc the actual hub therefore sits off centre so the wheel has to be dished to allow the rim to run central in the bike frame ?
And I added to it ? so let’s start with another question .I'm not sure you achieved less confusion, but maybe added to it?
Maybe start with "what is the strongest spoked wheel"? One that is symmetrical where each spoke is sharing the same force. Remember the era of rim brakes? The front wheel was strongest if it was correctly made because it was symmetrical. Spokes on both sides of the wheel were equal length, and if it was a well made wheel, each spoke had close to equal tension.
Now consider a wheel with a disk brake or cluster. The spokes on the rotor or cluster side are shorter and have more spoke tension (the spoke nut is tighter) than the longer spokes on the opposing side. They are also more inline with the load placed on the wheel. Essentially you have half of the wheel spokes supporting most of the vertical weight and vertical forces to the wheel.
this would interesting on an engineering exam paper . some mechanically minded people understand it just by looking at the rear wheel, it just an obvious solution to us , but actually explaining that to the person who doesn’t in words alone is a greater skill we all struggle with . The answers made sence to us who knew but not Andy So as teachers we all failed Sorry Andy ?
Does it have pop up's ?Read this Kernow.
It'll teach you far more than you ever wanted to know about bicycle wheels
Google's quite good isn't it?I must admit being fairly new to bicycle tech and jargon, it got me thinking.
So I had a little look online as I find visually sometimes can make something so much more simple.
This popped up and pretty much explained what I was thinking in my head in regards to the free hub and off set rims to achieve strength.
Well i think it makes sense now so i'll take that
Wasn't @Andy.M talking about offset drilled rims?Don't be confused. Just ignore Steve's post. It's nonsense..
Apac is correct.
No dish and even tension builds a stronger wheel. In order to achieve this with a modern cassette/Freehub rear wheel you require either offset dropouts, centralised equidistant hub flanges or an offset drilled rim.
Mastermind...Read this Kernow.
