Non drive side crank seal.
Arron M
67
45
How desperately do I need to replace this seal? Is the rubber part just a weather flap or is it part of the main sealing mechanism itself?
RustyMTB
2,842
6,878
I would do that sooner rather than later. Behind that seal you can see the yellow rubber o-ring/sub seal thing that forms part of the broken seal in your picture. Behind that in turn is a bonded seal. The whole assembly adds up to layers of protection against water penetration. @Bearing Man will sell you a kit for about £30 delivered with a tube of tacky grease that will restore the bike to how it came out of the factory.
You'll need a crank puller tool & snap ring pliers to remove the circlip that holds the broken seal in place.
Pro tip: If you diy it, the seal kit has plectrum like tools to lever out the seal. They're hit & miss as the seal can become pretty stuck on the shaft. You can use long nosed pliers to push against the inside wall of the seal & pull it off the crank shaft. It will be obvious when you see the seal. Just take care not to mar the crank threads machined into the crank spline.
6,544
5,036
not something that can easily be replaced so a repair would be best. Try using some liquid gasket. Clean the area with some IPA on a cloth first, then smear some grease on the crank below the area where the black rubber seal part is missing and apply the liquid gasket. Do not disturb the crank until it has set. The grease will prevent it sticking to the cranks.
Freeforester
38
37
Grampian
Sounds like a waste of decent beer!
Spangoolies
122
114
Depending on what motor you have:
Allen key, Crank puller, a pair of circlip pliers and 30 mins of your time are all you need to fix this properly
554K
