newbi with a buying doubt_Orbea Rise 2025
Ekaitz_B
Bizkaia
Hi everybody..i am Ekaitz from basquecountry
I am seriously appreciating ORBEA RISE and I have several doubts.
The M20SL comes with EP600RS engineThe M20LT comes with EP801RS.
Is the difference from one engine to another is weight or is there any difference in hardware or software plus?
The peak power max in EP801RS is 600W on the EP600RS as well? or is it 500W?
The difference from the SL to the LT apart from pneumatics, periphery etc....is only in the hunt race and the bieleta and the fork?pq being so what weighs more Fox36 would compensate for what weighs less EP801RS
Once the M20LT has been chosen there would be some configuration problem if you download the FOX36 fork to 150mm and you change shock travel to 210x50 so that it stays 140mm?the shock surely wouldn't do it is simple information.
Or the same situation with de SL H20 or in this case the LT H10
Paulquattro
2,292
1,271
The Darkside
Welcome
I personally know very little about the Rise but i see you have asked in the Orbea specific part of the site so hopefully someone can answer your questions (y)
552K
