Newb using Mission Control - map problem
levogirl
Arizona, USA
Everything is working except i only get the map of the world when i'm done. If i pull apart and zoom in, the ridden route is there. Nobody at the lbs knows why or how to fix it. Ideas, please!
Paul Mac
997
1,046
Uk
Something not quite right there.
When I turn on my mission control app it zooms right to where I am, so I can see the road name that I'm in.
mkelly82
Hull, UK
Quick suggestions;
1) Quit out and close the App completely before reopening.
2) Check for App updates and install as required.
3) Check App settings to see if there are any specific options Regards the map.
4) Restart your phone.
5) Delete and then reinstall the App remembering that you will need to de-sync before deletion and then re-sync after redownloading the App with your bike.
Hope that helps. Not sure what else to suggest. Good luck.
Donnie797
529
526
Germany, southern Black Forest
you say you get it when you’re done - maybe your Levo just wants to tell you, that it isn’t done yet ^^
Do you get this when you start up, too?
Also, the “locate me” icon on the top right corner is missing - so i guess the gps stops working (or the gps connection from phone to app)
What type of smartphone do you have? Any special gps or security or energy-saving settings?
554K
