Levo Gen 2 New Turbo Levo 2020 owner - and the (usual?) questions :)
ah1
102
40
Santa Cruz CA
Hello hello! Just got my first e-bike (pics below) and have a bunch of questions, forgive if they repeat - I did search other threads :)
  • Motor / battery care - is there anything to know? Should I avoid doing something with motor (e.g. steep climbs in high gear, etc)
  • Does the fork already come with volume reducers? I can open but prefer not to mess around if someone knows the answer
  • Anything I should know about storage (like leaving inside a hot car)?
  • Compared to your non-ebike, do you use slightly more pressure / less sag in rear shock, given it's under more weight? Or should I just go normal ~25% sag?
Thanks!!
aarfeldt
712
634
Denmark, Danstrup
Congrats on the bike....it's great.
Motor: dont go too low or too high cadance....you'll find out.
Storage inside car: okidoki.
700w battery (used) is allmost impossible, but can be sourced new
When washing....dont spray hard on electrical components.
apac
1,326
1,173
S.Wales
Keep your chain well lubed/waxed and soft pedal when changing gear. Otherwise Your chain will wear very quickly.
Try not to leave your battery fully charged for days on end.
my guess would be that your fork has one spacer installed. I believe you will need a 32mm socket to remove the top, and don’t forget to let the air out of the chamber first.
553K
