Unanswered New to mtb's trying to understand tyre/wheel size
Blue172
Kirkham, Lancashire
Hi all,
I'm totally new to Mtb's let alone eMtb's I've only ever had and still have road bikes,
I've purchased a hardtail as I'm only going to be riding fire roads and the odd trail so an hardtail seemed the right choice (I may change my mind later as I'm loving the eMtb)
My question is I have an 2018 Haibike hardseven 7.0 the tyres are 27.5" X 2.8"
1st - what are 27.5+ tyres are they just wide 27.5 tyres?
2nd - I've had a few flat tyres whilst I've been out mainly thorns etc, so what size tube do I buy 27.5 X ? As I can't seem to find 27.5 X 2.8 inner tubes also if I want new tyres can I get 27.5+ or just 27.5 plus what width can I go up and down to?
Gary
Old Tartan Bollocks
10,496
10,717
the internet
1 yes
2 if thorns are your main puncture cause definitely go tubeless
Tyre size is subjective, try lots and run what you like.
what width you can run depends on your rim width.
a 25mm (internal width) rim suits a 2.2-2.5 tyre best. 30 mm rim suits a 2.4-2.8 best and so on. You can run larger or smaller tyres on those rim widths but if going narrower or wider you'll need higher pressures to hold sidewall rigidity.
Norange
337
246
Wiltshire
Yep, for better puncture protection tubeless is the way to go. If you don't want to faff about, then a shop can set that up for you.
Your rims have a 35mm internal width. As Gary says, you don't really want to run much narrower, say 2.4 upwards. The terrain you're on would suggest something 2.4 to 2.6 which is fast rolling. Schwalbe Rocket Ron or Racing Ralph, Maxxis Forekaster?
Schwalbe
Maxxis
Re-Cycle
59
79
Netherlands
One thing to consider if you should want to go a little less wide is the ground clearance. If your pedals are already hitting the ground often I would certainly keep the 2.8 tires and not go to smaller sizes.
Apart from that it's personal preference which tire size suits you best.
573K
