New Stem suggestions
Clean
88
88
West Yorkshire
Hi folks,
I have a 2022 Stereo Hybrid 140 with 750 Power Tube. I bought the base model, as I preferred the colourway, and then slowly pimped it out with Team Sport components (drivetrain, shock, forks, dropper, etc).
I would like to replace the Stem, perhaps for something touch shorter, but am struggling to find anything with a similar rise. Any suggestions, please?
Thanks,
Clean.
KnollyBro
995
2,337
Vancouver
Hi folks,
Thanks,
Clean.
When is a stem more than a stem and with so many colors to choose from, what's not to love?
0.8£ 91% OFF|ZTTO MTB 50mm Stem CNC 35mm 31.8mm Handlebar Bicycle Ultralight 0 Degree Rise Durable DH AM Enduro 28.6mm Steerer Mountain Bike
Hattori-Hanzo
405
527
I'll be replacing my stock stem with a DMR defy soon, I went with the 50mm version but there is also a 35mm.
You may also need some stem spacers to replace the stock ones, or you can try cutting the little pin off of the top of the stock spacer so the new stem sits flush.
The stock spacer and cable management isn't the best.
I'm replacing mine with a Nukeproof set.
#lazy
E*POWAH BOSS
Oct 1, 2019
1,404
1,529
Bingo !
I should be on the payroll ☺️
Downhillr
289
153
SF Bay, California
Hi folks,
Thanks,
Clean.
What rise is your current one?
gooral
Peebles
Hi folks,
Thanks,
Clean.
What is the current rise of your stem? Hard to advise on something you only know....🤔
MrPeaski
260
210
South Wales
Archive page for the Stereo Hybrid 140 Pro which is what I think the OP has
CUBE PRODUCT ARCHIVE | Cube Stereo Hybrid 140 HPC Pro 625 carbon´n´metal
The stem is listed as CUBE Performance Stem E-MTB, 31.8mm, which is the same as @Downhillr has linked to.
in the product page the stem is lying on very front of the steerer part and faceplate bolts so gives the impression of it being lower rise.
The OP has the freedom to choose any suitable stem as his(?) doesn't have the hideous headset cable routing 🙄
I would also get rid of the stock spacers and fit standard ones to match the new stem...assuming the steerer section is 'round'
553K
