AaronWhitt82
Hello everyone,
New member here, new to E-bikes and also the Santa Cruz brand!
Just purchased a 2022 Heckler S 29" in Medium gray color. Couldn't beat the 25% off price!
I am coming from a 2020 Trek Fuel Ex 9.9 Project One AXS size M/L. I am approximately 5'8" with inseam around 31.5" so hopefully the Medium fits me good.
I've been doing a lot of reading on this bike and trying to learn as much as I can. I am located in Scottsdale, AZ so plenty of excellent trail riding out here!
I will be swapping over some of the parts from the Trek to the SC as follows:
SRAM AXS X01 Derailleur & Shifter
ROCKSHOX AXS Reverb dropper post 31.6 X 150mm
DT SWISS EX 511 Wheels with I9 Hydra hubs
FOX DHX2 Coil Shock with Cane Creek Progressive spring
Hope Tech 3 V4 brakes with Galfer rotors (Ordered a Tech 4 V4 for the front to see if much improvement from Tech 3)
Ergon saddle
DMR Vault pedals
NEW PARTS I WILL BE ADDING:
Fox Factory 38 GRIP2 with 170mm travel and doing a Vorsprung Smashpot coil conversion. (My Trek currently has the PUSH ACS-3 coil conversion)
SRAM XX1 Cassette
SRAM XX1 chain
5DEV billet crank arms or E*13 carbon (Went with 5DEV)
RideWrap tailored kit
RaceFace Turbine or I9 40mm stem
The main question I have as far as the DHX2 shock goes since I'm not familiar with VPP suspension... What is the best spring to run? Fox SLS (Linear) or Cane Creek Valt Progressive? Using the TF Tuned calculator looks like I would have to get a heavier spring from what I have now.
Other than that, I should be good with everything else. If anyone has any suggestions on anything please let me know!
Thank you,
Aaron
Ergon saddle
DMR Vault pedals
SRAM XX1 Cassette
SRAM XX1 chain
Thank you,
Aaron
