Levo Gen 2 New Gen3 Turbo Levo 700w battery
veryoldfart
68
73
Suffolk
Does anybody know for certain whether you will be able to use (with some new parts/ie connectors fitted ) a 2019/20 Gen2 700W battery in the new Gen 3 Levo?
If so, when might those parts become available or is that a very elastic piece of string?
More concerned about eventual likelihood than timing..
veryoldfart
68
73
Suffolk
Great idea - Have You tested the use of Your gen2 battery ?
My LBS confirms it will work and they have got the parts required to enable a Gen 2 battery fit Gen 3.
Seems the battery cells are same to both versions, with different adaptors.
Only a few weeks more until I can collect the new bike and try it.
The battery adapter parts were more readily available than the bike!!
Bencab
190
483
California
Yes confirmed. I have been using the extra battery since Feb; just order the new plastic parts.
Sep 19, 2020
99
94
Squamish, BC, Canada
You don’t need new parts if you just swap it over from battery to battery, but if you’re doing it often the new parts would be worth it.
I only swap the battery (and parts) out the rare time I go for two rides in the same day or when I forget to charge the 700.
Frank_Denmark
312
530
Denmark
Thx for input - I just got the part from BestBike - 70 Euro 👌
554K
