New firmware Bosch. how do I know if I have it?
fenwick458
295
187
Cumbria
Had my Motor (21 Wild FS)replaced recently, ever since I got it back I've thought it felt different.
Tour seems to be different, it ramps up the harder I pedal(I think). have they put the new firmware on it so it's now"tour+" ? I remember hearing a bit about this years ago but can't find any info on it now
the Purion still just says "Tour"
JP-NZ
1,189
902
Christchurch - New Zealand
Your LBS or Bosch dealer will be able to tell. I don't believe you can tell from the Kiox etc
Hobo Mikey
1,017
2,727
Where ever
If you have Tour + the display will still read just Tour. its a bit like an automatic so it puts in more power as you start to pedal harder, so it goes from eco to turbo depending on your power input. You should notice a difference on the battery also as it saves on battery. If you don’t like it you can get it taken off by LBS.
That’s the way I understand it works. (y)
552K
