New Chain on 12 speed shimano - thrumming?!...
edruid
96
53
Gloucestershire
Swapped out at just over 50% wear.
Shifting worked fine.
But now there is a constant thrum, no matter how I adjust the tensioner
And the chain now keeps slipping off the front ring (not great when you're in Snowdonia).
Lubed the new chain before use.
Definitely same link count
Not had this before, anyone got any theories?
edruid
edruid
96
53
Gloucestershire
Have you routed it around the rear mech correctly? There's a little tab between the pulleys, the chain has to be on the correct side otherwise it rubs.
Have you got the chain the right way around? Writing on the outside?
Thanks, would love it to be either of those easily correctable mistakes (which I have made before) but sadly not this time . . .
theremotejuggernaut
399
285
If it meshes properly, there will be no gaps between the chain and the chainring. The links will fit perfectly between the teeth (also, narrow/wide links need to be aligned with the narrow/wide teeth).
I'd flip the bike over and pedal it slowly looking at the chainring, if it looks like the chain is climbing out of the gaps between the teeth then the chainring is worn.
Also, if the chainring is worn, it can sometimes hold onto the chain as the chain moves around the bottom of the chainring. Look at the bottom of the ring where the chain starts heading back towards the derailleur. The chain should slide cleanly off the chainring. If it looks like the chainring is dragging the chain around, then it's another sign that it's worn.
Same applies to the cassette. The chain should sit nicely between the teeth.
edruid
96
53
Gloucestershire
Thanks dude :)
Stihldog
Handheld Power Tool
4,097
5,800
Coquitlam, BC
Quick Link? If you’re installing a new chain install a new quick link also. Usually one is provided with a new chain. …and these can be installed incorrectly.
A Shimano link for a Shimano chain. Direction of chain travel is important. That’s usually indicated by a small arrow. Insure that both sides of the quick link are “snapped” into place. That can happen and may cause problems while the chain travels around the chainring. ( if one side is not clipped properly ).
Besides the narrow/wide issue …chain suck can happen on an old or worn chainring.
But carefully check the quick link. They can sometimes be reused but a new and properly clipped link is important.
Shorty4
36
19
I had similar a few times now and it was the chainring every time, new chainring and it all works ok. I use alloy chainrings so the do wear quicker than a steel one but are not that expensive.
Its on a Focus Jam2 C Plus of 2018 vintage with Shimano 8000, still going strong at just under 10k kms
576K
