Need help with new Fox 36 forks
Shimanomike
24
27
Paris, Tn
So I had my lbs order some new Fox36 160mm forks for my 2019 Levo. I fit everything up, except the wheel, get everything cut, mounted it and then comes the wheel. Ooops, I have the wrong forks, or should I say the wrong size end caps on my wheels! Does anybody know if I can order the right ones anywhere? As you can tell I'm not the top notch bike parts guy but I can work on things. I was planning on having a friend turn them down to size but I thought I would check if I can order some first. Thanks for the help and no bashing my stupidity lol!
Shimanomike
24
27
Paris, Tn
I guess I should add that I had a Rockshox fork on it before and from what Ive read is that they use a tourqued cap which are larger. So I guess I need a standard cap. Got any ideas on where to order in the US?
Dewi
58
89
Melbourne
The torque caps can just be levered off, a standard cap size is underneath, well it was on the wheelset I have.
554K
