Need Help Please?
hjscm
63
32
Bay area ca
Ok so getting ready for a camping trip. My nephew jumped on my bike and broke the chain and the front chain guide. I have a spare chain but was wondering if i can ride it without the front guide? It looks like the threaded part on inside of casing broke. Wondering how easy it would be to replace and i don't the local shop would have something like that in stock.
Al Boneta
Dark Rider
1,351
2,602
California
The chain doesn’t stay on the front sprocket all that well for me on rougher technical terrain even with the chain guide intact.
Did the metal threaded anchor pull through the right side motor cover? If it did you’ll probably have to replace the whole cover. That’s going to involve removing the sprocket and spider with a gear puller. Any Specialized dealer should have the cover and chain guide in stock.
It’s quite common for people to step on the chain guide and break it or the screw holes to break on the right side motor cover.
hjscm
63
32
Bay area ca
yes the thread anchor pulled through. Hopefully they can fix it pretty quickly. If not i hope they have the pars and a puller and i can take it with me, and if the chain doesn't stay on i can somehow figure out how to fix it there. Is it a hard repair? Seems like you have done this before.
Thanks for the replies
hjscm
63
32
Bay area ca
I was thinking of using jb weld like you said. I am going to the shop and see if they have the parts and can do it. If not i will get the tools and use jb weld if chain doesn't stay on. How do the cranks come off? I tried but get about half a turn and it gets tight again.
Al Boneta
Dark Rider
1,351
2,602
California
Keep turning the bolts are self extracting
Al Boneta
Dark Rider
1,351
2,602
California
Sorry didn’t see this at first. Yes this happens to a lot of Levo owners. The hardest part of replacing the right side motor cover, removing the lockring and then the spider. Both of those require specific tools.
eFat
342
270
Switzerland
What tools are needed?
You can use a 24mm socket instead of "C".
  • Levo Motor Removal 2016.pdf
Al Boneta
Dark Rider
1,351
2,602
California
What tools are needed? I want to have them in my mancave :)
8mm Allen Wrench or Socket
A gear puller
The black round thing in the fore ground is the Levo bottom bracket axle cap to prevent the gear puller from damaging the threads.
I prefer the ISIS crank bolt top right because it threads in and is easier to aquire.
And a splined lockring tool
Tmacca
56
76
My chain guide also failed. After taking off drive side cover couldn't find the backing plate so just welded a nut to a washer and sanded down an old one up chain guide. Locking nut comes off with gentle persuasion from hammer and screwdriver, though tightening I had to make a quick n dirty tool. Also a coin works as a bracket axle cap with the gear puller.
Al Boneta
Dark Rider
1,351
2,602
California
View attachment 3377 View attachment 3378 View attachment 3379 View attachment 3380
Ingenuity at its finest, well done sir
hjscm
63
32
Bay area ca
That is awesome. wish i had a welder at home. my shop didn't have parts or the spline locking tool. i need to order one from amazon i guess. do i need a new cover or can i just order the chain guide and it will come with what i need? and where to order?
hjscm
63
32
Bay area ca
does anyone know what spline lock ring tool it is from park tool? trying to find these tools on amazon
Tmacca
56
76
(y)
you can just order the chain guide from local specialised shop, I did ask to make sure backing plate was included so just double check.
hjscm
63
32
Bay area ca
I ordered the tool should be here friday. I think if i have problems running without guide i am just going to jb weld the guide to cover and then order a new guide and cover and replace whole thing.
hjscm
63
32
Bay area ca
Thanks everyone for the help. I ordered the parts for chain guide, but will take some time. I jb welded the nut to the washer and hopefully it will hold. Was not to hard to take everything apart. Hopefully goes together just as easy
Dax
1,705
2,074
FoD
There shouldn't be any load on that when you are pulling the crank off...
hjscm
63
32
Bay area ca
Thank you for that. i will put a socket on there to get away from shaft next time. I tried to weld a nut on a washer but it was to long for motor to clear. I want to hardware store and found this. I cut it down with a dremel to fit perfectly. this worked well so far.
552K
