Waynemarlow
Been having a mystery tyre deflation whilst underway recently which had really started to irritate me. Pump it up and it wouldn't loose a bit of air whilst sitting in the garage. Ride it and sometimes it would be fine, the next suddenly you would loose 1/2 the air and needing a top up. No obvious leaks of sealant around the rim indicating a problem there.
Finally took the tyre off and found the cause, a cut about 5mm long right through the centre of the tyre, the sealant seems to plug the hole, but the cut was so big that when you hit a stone or root and deflected the tyre just at that point, it looks as though the sealant plug would be spat out and in the process before a new plug would form, 1/2 the air would go.
Mystery solved with 3 tyre repair plugs through the same hole, the sealant seems to do the rest.
