Mystery screw
peterk
76
27
Canada
I removed the battery in my Stance-E for the first time and found a small screw sitting in a small depression right below the electrical connector for the motor (see first picture).
There seems to be a missing screw on the bottom end of the battery. if you look at the second picture you can see a brass insert below the electrical connector that seems to be about the right size for this screw.
Any ideas? If anyone has a similar battery could you take a look at the connector end and see if there is a screw in that brass insert?
Thanks.
Alcove
57
63
Canada
I started having power cutting out issues on a ride. Finally noticed one of the 2 little screws holding the female battery receiver was missing and had play. Luckily found a replacement in my toolbox, snugged it up and all good since...
peterk
76
27
Canada
Guant quality control seems lacking.
552K
