My top 5 emtb motors choice....
B1rdie
878
1,079
Brazil
Does the bosch race keep pushing when you backpedal? I saw you climbing that rut and got curious.
I ask, because I use to make a minimal backpedal before shifting, as a means to have instant cut of suport and thus a smooth noiseless shift. This works with the shimano E8000 and bosch CX and non CX performance.
Streddaz
288
405
Tasmania
I would go for the new SRAM motor even though Bosch also is a good solid motor.
The new SRAM motor is the old Specialized Levo motor, the Brose Drive S Mag. ;)
I think the belt drive issue is fairly sorted now so it's still a good motor and easily serviceable.
If you are going to keep your bike for a several years, the Shimano and newer Bosch motors aren't great when it comes to servicing them as you risk damaging the circuit boards when opening the motor or getting a fault code that you cannot clear and bricking the motor. Unfortunately, they are throwaway units. :(
Onetime
451
460
Cali
No, it doesn’t give power when you back pedal. It does have overrun. As explained in the video, when you stop pedaling, the motor continues for about 10’.
TheSnowShark
214
278
French-Alpes
Thank you for this very good report.. :)
I live in a very mountainous region, either it goes down or it goes up, there is only a few flat areas, what would you recommend as a motor with the most overrun in order to be able to climb as best as possible in the rocks and the roots ?
Cheers 🍻
ari
47
21
I once rode a 750w hub drive , it had so much power ,had to brake on up hills also , quite unpleasant ride , so power delivery is the key ,not the amount , i guess .
ari
47
21
Cheers 🍻
Over run is governed by the UCI/ cycling federation , so pretty much all should be the same or few cm difference , a bit like the 25km limit.
Onetime
451
460
Cali
No, that’s only for racing purposes. None of the other motors come stock with as much overrun as the Bosch CX Race. But the overrun is only in race mode, not in the other modes. The regular Bosch CX doesn’t have the overrun either, even in turbo mode.
B1rdie
878
1,079
Brazil
Sorry, what I meant to ask is wether the motor maintains the overrun when you ratchet like that, because the motors I have do cut the overrun instantly when I backpedal, so that its impossible to ratchet like you did on that rut.
Onetime
451
460
Cali
Yes, due to the overrun, the bike will remain under power while ratcheting the pedals. 👍🏼
notaninfluencer
72
111
Italy
yes it does when u back pedal.
Hiltix
34
61
Bern, Switzerland
You also got overrun (called "extended Boost" by Bosch) in eMTB Modus but less.
Paulquattro
2,177
1,205
The Darkside
I was just about to pipe in and say my 2022 motor gives over run in EMTB mode but you already had :)
What the difference between the Extended boost mode and the cx race over run ?
Hiltix
34
61
Bern, Switzerland
The overrun time of xtended Boost lasts longer. This is very helpful when for Ex. climbing rock steps. However, you have to get used to it first when the motor is still pushing at full power for about 1-2 seconds without you pedaling. And it only takes a little kick to activate the extended boost again.
Astro66
173
302
Sydney Australia
The Shimano EP801 has just been given the 2 metre overrun feature. But backpedaling does immediately stop it. So the technique to use it multiple times whilst flat pedalling and pulsing the pedals, is to only back pedal after nearly 2 metres, and pulse it again.
Would require some practice, so it became muscle memory. But I would actually prefer it to cancel with backpedalling, so you can stop it if you need it.
Onetime
451
460
Cali
As a few others have pointed out, this is incorrect. The CX does keep powering forward when you stop pedalling.
I had a 2022 CX and it didn’t have any overrun. I now have the 2024 CX Race and it does in race mode, but not in the other modes.
ari
47
21
We all know that the overrun is there to stop the jerkyness /to give the power delivery on each[in between] pedal push / stop the/on/off scenario , yes? so every ebike has overrun ,otherwise it would be unridable , but the distance can differ .
JP-NZ
1,144
866
Christchurch - New Zealand
No. quite simply there is no difference in feeling between modes in Bosch at least. There is definitely no "jerkyness" between modes
JP-NZ
1,144
866
Just so we are all on the same page, the attached press review from Flow MTB magazine.
One of the most impressive features of the latest Bosch Smart System is the Extended Boost. This refers to how much the motor continues to supply power when you have stopped pedalling, which is also known as ‘overrun’.
The Extended Boost function is only found on the latest Smart System-equipped Performance Line CX motors, and it’s only applicable in the adaptive eMTB assist mode. You still get some overrun when riding in the Eco, Tour+ and Turbo settings, but it is not nearly as pronounced.
When using the eMTB mode, the Extended Boost provides consistent motor support for an additional metre of riding when you stop pedalling. As you can imagine, this is hugely beneficial when you’re riding up a steep and technical climb with lots of big ledges to get up and over.
The downside of Extended Boost is that it can feel like the bike is pulling away from you if you’re not ready for it. For example, if you stop pedalling just as you come into a slow-speed corner, the motor will keep driving, potentially pushing you wide and off the trail. We’ve found it fairly easy to adapt to, but lighter and less experienced riders may find it overwhelming.
Those riders have two options. You can simply ride in the Tour+ mode, which still provides adaptive assistance but with less power than the e-MTB mode. The other option is to take your bike into a Bosch dealer to disable the Extended Boost function. To do so, the motor’s maximum torque output will also be reduced to 75Nm.
543K
