Levo Gen 3 my levo suddenly wont charge - because of the temperature?
Razorx
46
10
Sweden
I went down to my cold storage? .. its like 23 degrees farenheit if my calculations is right.
I started the bike and it was at 23% so i decided to charge it cause i might wanna go biking in the afternoon.
Put in the charger and nothing happens.. The charger itself shows green light but nothing on the bike.
I removed the charger and tryed starting the bike... Now the bike wont even start.
Tryed everything all over again and no sucesss. Its a 2024 model...
Could it be the cold? its not even that cold i think.... What do i do? Suggestions?
Razorx
46
10
Sweden
Seems to be a real hazzle to have to be doing that?!
If the cold is the problem... is that what people do? Take the bike inside to charge it during winter?
Removing the battery is not so easy so i would like to do it everytime i want to charge either during winter.
Weeksy
537
559
Reading
Then just take the bike somewhere warm and charge it and try and get it stated.. clearly that will answer the question easier than any other option?
Razorx
46
10
Sweden
Hehe yes ill try that. I really hope this is not the solution for everytime i want to go riding during winter...
If the cold is what the problem is im a bit dissapointed.. its not even that cold.
last year i went biking more than every other day. So if i have to remove the battery to charge it everytime im not happy :D
Never had this problem with my old bosch cx... and rode alot colder tempreatures than this.
Bazzer485
54
29
Redding CA
There has been many problems in electric vehicles not changing at low temps. To remove the battery all you have to do is invert the bike or lay it on its side undo a single bolt to remove the battery, take it inside and charge it nonce it’s warm.
It doesn’t matter what brand of bike you have they all use lithium cells which will give low performance at low temps.
Who want to ride at 23 degrees and freeze your junk off?
xtraman122
251
186
Plenty of us live in places where it gets cold in the winter, but as long as there’s no snow/ice you can still have an enjoyable ride, you just need the right gear. I just went on a great ride on Sunday where it was below freezing the whole time but a beautiful day outside otherwise. It’s ride in the cold or go months without riding for many of us.
Razorx
46
10
Sweden
I ride all year round and enjoy it. Its alot of snow outside where i live so it gets cold...
Well the problem seems to be the cold. I removed the battery and i let it get warm and then it started charging.
Its not hard to remove the battery but to have to be doing that like everyday from now on sucks...
As i said its not even that cold!?
My old bosch i had for like 5 years and rode through alot colder days than this. Never had any problems.
Mina08
77
71
Sweden
I have a small fan heater pointed at the bike when i charge it below freezing, and put the heater fan on 30mins before taking the bike out for ride, the battery takes 30secs to remove, 1 bolt.
9,573
I had a similar problem with Shimano set up on my Focus Jam2. It was the charger that was the problem. Whenever the battery and charger were below 10degC, the charger refused to charge. If I kept the charger in the house, problem solved. But during the process of discovering what the problem was, I got my bike supplier involved (all still under warranty). Focus insisted on replacing the battery (despite me and the LBS having proved it was not the problem). The LBS gave me a new charger from a different batch and the problem stopped. People all over the world were having the same problems with the same batch of chargers that I was having problems with.
The amusing point was that Focus still believe that it was the new battery that solved my problem. :rolleyes:
559K
