My 2019 Levo with a Dhx2 = bliss!
Ddc6284
128
90
Saint Louis MO
I finally received my DhX2 210x52.5 600lb from fox yesterday...
I already had upgraded the rear to a Factory Dps, was a pretty good improvement over the RS. I could never seem to get the rear plush and stable being 220lbs+... Have a fair amount of Rock gardens and rooty trails where I live.
My first ride on the Dhx2 was night and day! Was simply amazed at who smooth & planted the bike feel now. The few Black trails I have near me... Now feel like blues.
The most surprising thing is the bike feels better in turns G-outs etc. Feels as poppy as the Dps too. Minus the wheels and brakes this is far the best upgrade I have done. Highly recommend it. Also excited that it's just going to get better the more dialed in it gets.
I actually feel the difference each compression click I make unlike the other shocks I've tried.
Rich the gasman
178
260
North east
Looks awesome mate, really want a coil shock myself now.
Ddc6284
128
90
Saint Louis MO
Think I'm @ 32%.... Kinda wished they sent me the 650lb. Don't have many drops on my local trails. I took one about 3ft. Didn't bottom out... At least don't think I did.
Trumpet
98
69
Stamford lincs
Mmmmmm..... kashima
Ddc6284
128
90
Saint Louis MO
Still happy with the DHX2? on the fence between one of them or a Ohlins coil
100% Changed to a 650lb spring and once I got the settings right. It's perfect. Soaks up everything and still feels poppy and playful. Only negative is... Now I want the ACS3 conv for my Fox 36.
Marf83
39
15
Derby
Hi Guys,
This is exactly what I’m looking for (being a heavier rider also). I’m very new to all this so a lot of it goes over my head.
Can I ask, did you go to Fox direct or through a dealer as my local one didn’t seem to eager to help.
Also, what kind of cost am I looking at (if you don’t mind me asking).
Thanks in advance.
Ddc6284
128
90
Saint Louis MO
Hi Guys,
Thanks in advance.
Ordered from Fox over phone..a little under $700
Rich-Baillon
70
77
I really like the 36/dpx2 combo and run this on my Yeti. However does the DPX2 mean that you can no longer fit a bottle on the bike. After years on a bottleless Yeti I am liking having a bottle on my Levo?
All Mountain Coaching
1,332
980
GB
You can run a bottle with tweaks. I've seen offset mount for the cage and smaller bottles. Helps if your swat tool is in the steerer.
Leobs81
12
9
Italy
Will this set up blast in the enduro side of the Levo?
I'm not a howner of it but thinking to get it.
Unfortunately as a standard mount the only reasonable bike is the s-works the other expert...comp and so on oem suspensions are really on the cheap side with pour performances.
So I was thinking to get a comp probably carbon and immediately upgrade the fox rythm 34.... and probably next year ho for a coil shox. What do you think?
Should I act differently?
The aim is to have an agile fast running bike for enduro racing.
Karel Tyc
22
47
Prague
the best looking levo I have ever seen. Awesome!
Tuckya'in
14
14
Washington State
Just did the same thing. Went from stock to DPS, to DHX2. Haven't ridden it yet. Also fresh wheels and similar brake upgrade. Great minds think alike.
Curious where you ended up with the clicks? I used the Fox starting point and it seems pretty damp.
559Enote
14
7
Fresno, CA
I have just ordered the new FOXFactory HDX2 210x55 with an 800#/in coil. I'm just shy of 300lbs all dressed. I ride a 725#/in Ohlins on my 2019 Kenevo. I have had a DPX2 210x55 on for the last 6 months on the Levo. Runs good but too much sag at max 350PSI. I have ridden it with the largest volume reducer allowed in this configuration. I don't bottom out on drops but we too much sag I'm constantly peddling striking. I ride most of the bike stock otherwise besides Santa Cruz Reserve 37mm wheels (DEVINVE upgrade). Next up is a 160mm fork - Fox 38 or 36E are both in play but have not made a call yet.
JetSedgwick
384
1,006
Lake Tahoe California
Love your bike...post more pics? I'd be curious to see the rims a little better.
576K
