Levo Gen 2 Mullet and low BB
Howz
419
480
Chester
I’ve just mulleted my 2019 carbon comp, really like it and also fitted 155mm cranks, but I’m finding that the BB height is now lower and catching on going over logs etc, what’s the solution to get the BB a bit higher? Will an offset bush fitted the wrong way give me a bit more height?
Plummet
Flash Git
Mar 16, 2023
1,152
1,634
New Zealand
Put it in the highest bb setting. But at 27mm bb drop in the high setting is too low for me.
If you really like mullet then the ultimate solution is to sell the bike and get one with less BB drop.
Otherwise you are trying to put a bandaid on an axe wound. The bb is really too low.
15mm bb drop is the max i want to go to on mullet set up.
553K
