Beekeeper
🍯Honey Monster🍯
How easy is it to access the motor mounting bolts to check if they are loose? Cube reaction hybrid 500 (2019) version (old motor)
Easy mate. The bash guard is in 2 halfs and held with 2 metal clips in the middle that keep them aligned. That's the hardest bit, getting those to line back up when putting it together.
1. Pull the crank with crank puller tool.
2. Undo the small allen bolts on the bashgaurd on the same side, the side you have taken the crank off. Just loosen the 2 on the other side (drive side)
3. Undo the bigger allen bolts and pull the motor cover off.
4. Tighten the motor bolts x 3 and the torque head bolts x2
5. Put it back in reverse order.
You can clean the crap from out of there whilst in there. Mine was well dusty
If your bike is creaking and you have checked your seat 100 times like I did then it will the the mount bolts
Yes that's what mine was doing (same bike, same year)
When I put pressure on with my left foot it sounded awful. They were not even that loose, quarter of a turn, if that. But it was enough to stop the creaking and have a nice quiet ride.
My cassette came loose the very next day after fixing the creak so you might want to check that too. I had 2 hours of quiet then that started making a row.
They are on the non drive side.
You only need to take off the one side. See pictures...
View attachment 29639 View attachment 29640
I changed my original 15t front sprocket to a 16t by accident when the original one wore out and I was under the impression that it was 16t.
There isn't much difference, but I think I preferred the 15t as it's hilly around here and I use the granny gear on the back more than I use the highest gear.
Tightening the nuts will solve it. I couldn't believe it either, just by tightening them a tiny bit would stop that god awful noise. The sound was like a penny been rubbed down a comb but louder lol
At the start of every ride I still listen for it to start but still silent a month on
That sounds like pretty good explanation. Especially when all you have to tighten them is such a small amount.
I didn't find that explanation when I was researching it so thank you. I just thought they had come loose somehow.
Well that is strange. Did you check the torque head nuts too Think they are T30 ?
Well then I'm sorry I was wrong. I would have put money on it to be fair as its the same bike as mine.
I don't have a clue then sorry but will carry on watching this thread in case I get the same.
Not sure of correct torque setting but I’ve been doing mine up to 20nm. You should also check the three torx screws. I did the wife’s bike yesterday, it looks to me Like the 3 hex bolts hold a bracket to the frame and the torx bolts hold the motor to the bracket. I could be wrong, but that’s what it looks like to me.I only used an Allen key to check the tightness. It seems all those bolts have the torque settings printed on them. Did you notice that as well?
I’ll check the headset next and if that doesn’t work I’ll give the motor bolts another go with a beefy torque wrench ?
Not sure I’d want to go to 25-30 Nm without knowing what’s on the other side of the bolt. If its a steel nut, no problem, if it goes into an Ali section of the frame I’d be very cautious.Obviously take this with a pinch of salt As I don’t want anyone to damage their bikes but on another forum, somebody with a Cube bike contacted their dealer about the torque settings and this was quoted...
- (3) 13mm Engine Mount Bolts 25-30 Nm
- Torx T30 Front Engine Mount Bolt: 13-15 Nm
- Torx T30 Rear Engine Mount Bolt: 9-11 Nm
- Lockring 20-25 Nm
My bike is a 2018 Cube reaction hybrid race 500.
Quite soon after getting it I started to get creaking.
It turned out that the crank arm bolts were not really tight enough.
Later on, the motor mounting bolts became loose.
The enduring solution for me was to apply blue Loctite to the motor bolts and torquing them up. I have attached a table with some more torque settings.
Similarly I used blue Loctite on the crank arm bolts and tightened them up to 50Nm.
I definitely recommend using torque wrenches as 25Nm is quite a decent tightness to achieve with Allen keys.
Also, I replaced the seat post clamp with one that you tighten with a hex drive and applied copper anti seize paste to the seat post. The standard clamp wasn't quite strong enough.
I expect my bike to make no noises as I'm a bit ocd about it and these solutions have definitely worked for me.
HTH!
