Motor Mount bolt creak issue solved...
FatladonanEbike
Staffordshire
Hi there everyone, my apologies if this is in the wrong section as i'm new to the forums.
However, the issue with the BDU2XX Bosch Performance Line CX with the creaking bolt mounts when pedalling. i think i have solved it by using some non slip self adhesive furniture mounting pads (as seen in the link) Amazon Link
i was using the official Bosch foam pads you can buy which other members have posted on the forums which only worked for about 100 miles then the creak returned. But since using the above pads from amazon the creaking has been eliminated and makes for a quiet ride.
what i did was cut them to shape to somewhat match the Bosch spec with some bits of pad added here and there for extra padding. A straight forward install which shouldn't be too hard to complete.
hope this helps people with the creaking issue as i've had. :)
554K
