Jeffw
Hi
Picked up my bike a few weeks back and will change the tubes out and go tubeless
It would appear i don't need rim tape. Is that correct?
I'm off to Glentress and Innerleithen later this week, so don't want to mess up the rims
The wheels are
From the Mavic site:
The right wheel and tire combination can improve your skills and upgrade the performance of your E-bike on challenging off-road terrain. The new E-Deemax S is built specifically for E-bikes and has some unique technologies to help you ride smoother and have more fun on the trail.
Our patented PFP technology (Pinch Flat Protection) features rims with a wider contact surface at the top of sidewall to significantly reduce the risk of tire cuts and punctures. The 30mm wide rims allow you to run lower tire pressure for better traction and smooth rolling efficiency. Our patented Fore technology features a fully sealed upper rim bridge that eliminates the need for rim tape, making it the easiest system for mounting and changing tubeless tires
Any comments/thoughts appreciated.
The wheels are
E-DEEMAX S 29
