Mission Control app not connecting - Kenevo 2018
jallabanan
24
Norway
Hi,
The Mission Control app will no longer connect to the bike. It just says "Connecting" - and then disconnects immediately Look at this video: Dropbox - Screen_Recording_20200408-154052.mp4 - Simplify your life
Phone is Samsung Galaxy S10 / Android. Location service is on and approved for the app.
Don't know if it's related, but also one led is red all the time (even with full battery) and one led is dead. Look at attached image below.
Any ideas or suggestions? Thanks a lot!
Tim69
180
210
Israel
I'm not an expert on it, but the red led on the batt. Is s fault code. Telling you something is wrong with the batt.
Check the manual or your LBS
I'm sure someone with more knowledge will give you more details soon..
Tim
chrisdut
30
17
Chester
I couldn't get my Samsung S20 Ultra to connect to my 2019 Levo, kept getting the connect/disconnect on loop
I erased all paired devices, removed the bike from mission control, uninstalled the app
Turned phone off and then back on again
Installed mission control
Paired my phone to the bike via bluetooth
Opened Mission Control and added bike
Bingo, all working again
Funkeydunk
389
297
Uk
I was also having trouble connecting, but now it connects but takes several goes to change the presets. So even when it’s connected it fails to change the modes properly. Not sure if it’s the SW update on the app but it worked fine a few weeks ago with no drama.
Dave 80
43
42
Belvo will solve this problem it works with my 2019 levo comp. Also no walk assist lock out.
552K
