Hi all. Just wondering if anyone has fitted Miranda cranks to there EP8 motor and used the crank safety plate or simply relied on the plastic end cap should they come loose? I have tried to install the Miranda cranks and the plate isn't fitting correctly. It looks as though the bolts are a little closer to the crank spindles than the shimano cranks. Thanks in advance
